Almost going to be going through the process of Glenn making me an amp. I spent a lot on tubes for my WA33 now I want to spend less and later decide if more expensive is my route . What are good tubes for rectifier, output, and driver. going to be using this for my Verite and mainly listening to EDM. Trying to go through the thread but I'm getting overwhelmed. I need a base line.
I am mostly listening with a Verite Closed and also mainly listening to electronic music.
For good tube combos, you certainly review the thread history. There are many, many, .. rolling options.
If I were re-speccing my amp today, I might replace the 6SN7 socket with 2x 6J5 sockets. You would miss on some dual-triodes. If you have a load of 6SN7, etc and want to keep using them, then keep that socket. IMO (and supported by others on the thread), anywhere you use a 6SN7 2x 6J5 is better (or at least as good) and cheaper. These are my main inputs. I do use the c3g sockets, mostly with adapters. I guess you could replace the 6x c3g socket w/ 2x 6J5 but I use the c3g sockets.
This link is quite out of date, but one day scrolling through this thread, I captured some tube recommendations and tube pairings in
this sheet.
Output-wise, I am on Bendix 6080s and have not found anything better for me. I have not spent the money on something like
GEC 6AS7G or WE 421A tubes (which are crazy expensive right now). I have sometimes used a 2nd pair of other-brand 6080 tubes with a pair of Bendix 6080 (2x Bendix does not work well for me and it is hot hot hot). The 6x 6BX7 output didn't really work for me, but I only have 1 set. 6x 6BL7 I like OK, but not compared to the Bendix.
In closing, if I needed one set to minimise tube cost, with the Glenn OTL, I'd pick the 6080s mentioned and a pair of GEC 6J5s. For me that requires/includes an adapter (from
@Deyan) for 2x 6J5 > 6SN7 socket (which would be the default case for most Glenn OTL amps I believe).
On another note,
@Deyan has just completed 2 more pairs of adapters for tubes I have in the cupboard. New rolls soon!
Listening to just now...
