cantsleep
opened the box. and wonder.. no wires..
do i have to buy the wires seperately?
Originally Posted by cantsleep opened the box. and wonder.. no wires.. do i have to buy the wires seperately? |
Originally Posted by SysteX Yes, you'll need to get some speaker wire. Anything larger than 18ga or so should be fine (Note: 12ga is larger than 14ga, which is larger than 18ga--it's a slightly counterintuitive naming convention). |
Originally Posted by Electro Point After reading all the reviews on these speakers seems like they perform like a $100 shelf speaker but at half the cost. I'm looking into buying these sometime soon. Does it acutally have like a 5-way binding post in the back of the speaker or am I forced to use banana plugs? Also is there any other info I should be noted about these speakers? |
Originally Posted by Hirsch They have binding posts. Very nice ones, actually, however, I think the spacing is wrong if you have dual banana plugs. The people I have played these for have guessed the price to be anywhere between $200 and $1000 ![]() |
Originally Posted by flamerz I did a bit of research, but I'm too lazy right now to do extensive searching. Could someone give me a simple answer of whether or not a T-amp would be suitable for these speakers? Thanks. |
Originally Posted by ssingh0 I'm using them with a t-amp with 8 AA batteries. It clearly does not have enough power, speakers start distorting past 1'oclock on the t-amp knob. I don't know how others can use them with a regular t |
