shuto77
- Nov 25, 2013
Hey, so how does this compare to the Oppo HA-2? Is it more powerful?
Well, it showed up and is charged. Will give a good listen with the phones I have and then will try them out with some hard to drive ones. Some people have reported they like the ha-2 with even the hd800s
Could you please also share your comparisons of Walkman->Headphone to Walkman->PHA1A->Headphones?
Well, in brief, I'd say that with the MDR-1a, I can't tell much difference between A17->1a and A17->pha->1a. The only think I'd say is that the bass may be a bit too much IMHO when using the PHA-1a and the MDR-1a
On the other hand, with the SR325e, the amp makes all the difference and if I listen to any digital source with the PHA-1A and the SR325e it sounds great. But the sound can be a bit thin and underpowered with the A17 direct to the grados.
The jury's still out on the PHA-1A vs the HA-2 with the Grados. The problem I had with the PHA-1A had nothing to do with sound quality, but rather to do with its lack of ability to play gapless albums with stuff I'd either purchases from iTunes or had matched to AAC 256 with iTunes Match. The sound with the PHA-1A and SR325e is great if you can put up with that hitch between tracks.
I didn't like the PHA-1A with my iPod Classic 7G because I seemed to get random pops and clicks on quiet passages of music using that combo that didn't appear using either the A17-PHA1A combo or the iPod alone. Seemed it was some digital error in the transfer to the DAC. It didn't even go away when I bought the $120 VentureCraft cable between the iPod and PHA-1a. Nice cable though...
With the HA-2 and iPod, I don't get those same random clicks, so now my comparison is down to the A17-PHA1A and iPod-HA2. Don't have a cable from the A17 to the HA-2
http://www.amazon.com/dp/B00YWEHSQY
Maybe someday but probably not. More likely to start chasing Sennheisers and even higher end Grados
The ha-2 is much tinner and also good, also feel heavy
Are these silicone belts (or bands) available for sale anywhere? Thanks...
hi guys, anyone use this with iphone 6p? does pha-1a has better dac from i6p? usually i use nwz-a15 which in my ears produces better sound for my rha t20 than i6p, but now iam fond to apple music which force me to use my i6p again everyday. im also curious about k1 and q1 but it seems pha-1a is better? so if i use pha-1a with my i6p will it sounds better or even surpass my nwz-a15? and also can pha-1a be used for laptop usb dac? thank you.
when you use a17 with pha-1a, does it sounds better from a17 alone? this means a17 bypass it own dac and use pha-1a dac right? if it does i will take pha-1a considering a15/17 is already better than my i6p.don't have a 6p, but have used both the pha-1a and the oppo ha-2 with my iphone 5s. I prefer the oppo for use with my iphone and use the pha-1a with my nwz-a17. Not because I prefer the sound from one particularly over the other, but because the ha-2 works well as a battery bank with my 5s and the pha-1a works well with the a17 in that both devices can be charged together with one cable, while listening.
Also, the pha-1a can be used for a laptop usb dac. not sure about whether windows drivers are needed, but on my macbook air, it is plug and play.
