G.Trenchev
- Mar 12, 2010
How's the offset after warming up ?Does it change ?
Hi, go for it (...but first consider re-labelling either the bottom left power connection or the left FET gate because they are both currently called ground!!!)
You might also benefit from small caps at each FET from drain to PSU ground.
I hope it works well, : )
No. The bias is tuned for maximum transistor's linearity.
Such psu will be ok, but you will need C-R(or L)-C filter anyway. you may use a 7812 - it doesn't needed any extra resistors.
The simulation will not be correct because of simplified lm317 model.
Here is one more intresting schematic.
Do you have this schematic in a better resolution where it can be read? I think it is showing a servoed CCS on the top of the mofsets controlling DC offset that way. This would give much better PSRR than the other solutions posted thus far.
Looks nice and simple!
I can't quite work out how C1 is working? Just passing positive rail noise to the junction of R1 and R2?
Is the gain simply - R3 / R9 , or does R5 have to be factored in?
Should have a lot of PSRR!
