2 or 3 Channel, Single Ended Class "A" Design Thread
Aug 13, 2010 at 11:29 AM Post #77 of 87
a little quick with the "thread crap" card there regal
if you had clicked on the link to my post you would have seen a SE Class A Pass design - seems like another Pass amp and the idea of scaling them for headphones was introduced by the op - is he dragging the thread off topic now because the later one Avro_Arrow posted was actually push-pull instead of single ended?
I think the class a Pass design was already scaled down for headphones ,  check the headwize archives,  still has the big output cap,
You suggested dropping the mofset entirely,  I am interested in this thread because the design is global NFB free more than anything as I think most are.
Aug 13, 2010 at 11:47 AM Post #78 of 87
The active ground with its relatively high output impedance can weaken the bass response.
The output impedance of the active ground channel is exactly the same as the signal channel in most amps.
The output impedance is doubled for that, but 2*~0=~0 The last schematic in this thread has global feedback so output impedance should be very low ~0ohms.
In the case of stuff without global feedback, like a simple szekeres which has a non-zero output impedance, is the additional output impedance from a 3or4-channel circuit worse than the output caps in a 2-channel version? A 2-channel Sezekeres with DC coupled outputs puts the power supply caps in the signal current loop between ground and V+/-. A 3or4-channel version with the outputs all at +6.000V breaks the signal current loops through the PS caps AND dumps the output caps.
Aug 14, 2010 at 12:39 AM Post #80 of 87
I built the VE and the mids were good,  but the noise floor relatively high and there was a bass rolloff when RMAA'd.
I assumed it was from the mofset ground channel.   I far as adding global NFB I would really lose interest,  just building an opamp at that point IMO.
 I knew I could fix the noise floor with a good shunt supply but the with the bass rolloff I lost interest.  Why do you think there was a bass rolloff?
Sep 18, 2010 at 10:39 PM Post #85 of 87
Yes, a BJT would be better and it also bias's the op amp into class A.
It has been pointed out to me that all this has been done before and
is a useless road to follow so I have moved on to other things.
I have a Zenhead and a DOZ waiting to be etched and I much
enjoy my Szekeres VE3 just the way it is.
Sep 30, 2010 at 2:10 PM Post #86 of 87
I know this is an old thread now but...
When did I show a push - pull design..?
The closest I got to that was the active current source...
and I have posted circuit ideas showing the principles behind using op amps with their outputs biased in Class A for the whole output range - I could easily show these with SE instead of push-pull - again it seems Avro_Arrow has included chips in input and output in his posts so far
Sep 30, 2010 at 3:04 PM Post #87 of 87
My good guess:
In other amps (from the design thread for the RJM twilight on head-fi, and experience with the MELOS) I have seen very non-ideal behavior from mosfets/jfets as followers. My instinct is that input impedance is related somehow to frequency, and drops as frequency drops. This combined with the output impedance of the POT and Rgate could account for drop if they were high enough relative to the new lower actual input impedance of the FET.
