Brightness is the incorrect term. It's black level. What black level is it increases or decreases the amount of black. So if someone's black hair looks grey, and if the whole image is washed out and you have grey shadows it's too high. To low and you can't see anything.
If the amount of light is hurting your eyes, you need a) Increase amount of light in your room b) Reduce backlight c) Disable dynamic contrast. d) reduce contrast (although LCD works better at higher contrast setting, instead adjust backlight to suit)
What makes it "brighter" is dynamic contrast (turn this off) and the contrast setting (proper term is white level) Plus your set may have other contrast enhancing features, turn those off.
im still finding it hard to justify plasma, due to the cost, slight possibility of burn in and the fussyness on the SD picture, looking at the tv in my parents room, it isnt good for SD, nor was it in the shop.
i was still really taken by the lcd, and i like the vibrancy, and its what im used to with pc screens, hmm, most say plasma but the best are out of my price range too |
For SD, plasma wins hands down. Even with a tweaked LCD it's not as good as a plasma. For videos and movies choose a plasma. For computer use or gaming only set choose LCD.
Screenburn is a concern.
A TV should not look vibrant, as that shows
1) Too much dynamic contrast
2) Too much colour
3) Other things to enhance colour DNI-E or black adjust
4) Too high overall light output.
5) Too much sharpness or edge enhancement
A TV once set up should look boring, as in it should not look cartoonish when showing regular TV programs.
I've owned several LCD's from 32" to 42", and a couple of plasmas 50" Overall I'd give the nod to better picture quality to the plasma. But a well setup LCD can look pretty good, if you're not hyper critical.
I would recommend you buy a DVD or BD video calibration disc, at least use it for sharpness and black level (brightness) adjustment. I don't agree with using it for contrast as that ignores what your room lighting is like, for example on a plasma to get no white crush you had to set to about 38/60 (Pioneer) but this is way too high in a dimly lit room, even with a backlight.
You can try adjusting sharpness, bring up some subtitle or telet.Make sure you disable any settings like noise reduction, edge enhancment, and other processing. Increase sharpness to maximum. Walk up close to the TV say 2' You'll notice it'll have halos around the text. Now put it down to minimum. It should now appear blurry and out of focus. What you want is just between the two, just so it pops out of becoming blurry but not high so halos appear. When you have this set up correctly it means you're getting more detail and less artefacts.
In addition, on the default "Standard" setting on Samsung LCD/LED TVs, there are other hidden automatic picture controls (such as Dynamic Contrast) that are either enabled by default or cannot be disabled at all unless you switch to the "Movie" setting. For example, the Warm1 and Warm2 color temperature settings are available only in "Movie" mode and cannot be set in "Standard" or Dynamic" modes (in those latter two modes, the only selectable color temperature choices are Cool2, Cool1 or Normal--and in my experience with Samsung LCD TVs, the Normal setting is still a bit too bluish in an incandescent-lit room). |
Agree with that, normal is too blue use warm 1. Warm 2 is a bit too warm colour temp. There is a way of getting all of Samsung picture modes (dynamic even) to look decent you go into service menu, you can then manuall force dynamic contrast to off in the dynamic preset. Great as you can have useful multiple settings per input. That's one thing I liked about Samsung (shame rest of the sets are crap though)
