mjb
- Oct 26, 2005
There are basically 3 types of digital inputs on a DAC; coax, optical and AES/EBU. To connect to these from your computer (without converters in between), you need the same "type" of connection on your sound card (the way your computer is able to send the digital out to the external DAC).
Coax has 2 types of connectors, RCA and BNC. BNC is typically quite rare, so you'll most likely use an RCA connector. To connect the computer and external DAC via coax, you use a 75ohm RCA digital cable. Sometimes one or both ends will be "mini" RCA, in which case you simply need an adapter (or custom cable if you don't like using adapters).
Optical is also known as Toslink, a square-ish connector. For this you use a digital optical toslink cable. It can be plastic or glass. Again, one or both ends may be "mini" optical, in which case you can use an adapter (or get a custom cable).
AES/EBU is an 110ohm XLR connector.
If you get a USB DAC, you can simply plug the USB cable into your computer and the external DAC shows up as another sound card on your computer. None of the above connections are necessary.
There's also many proponents of WiFi connections (Airport Express, Squeezebox, etc). This device acts as an external sound card which you use via WiFi and appropriate software/clients. These devices are much like sound cards in that they can be used with or without an external DAC. If you use an external DAC, all the above applies between this device and the external DAC.
Regardless of the way you connect the DAC (even for USB), if you use Windows, you'll want to use ASIO or Kernel Streaming of some sort because Windows resamples (changes the data which makes up the sound). Kernel Streaming is a feature of a few of the music playing clients, e.g. foobar2000, which allow you to send the music file data directly to the sound card without going through the Windows kmixer (where it would have been resampled). ASIO is a bit more complicated, but basically it does the same thing...except your sound card/drivers must support it to use it. Basically, when people are talking about whether a sound card is bit-perfect, they're referring to whether it is resampling (or otherwise) changing the sound file data before sending it off to the digital out. There's a ton of info on these subjects, so I'll stop here.
Which configuration sounds better, what's the best for this or that is not necessarily straight forward, so I'll let you read the volumes of threads on the subjects
I hope this was some help.
mjb
mjb
