1MORE H1707 Triple-Driver Over Ear
Apr 9, 2021 at 4:48 PM Post #1,351 of 1,601
If it is from the cup, it can be the glass being a bit loose and hitting the metal "rim". You can put a little bit of foam between them or tape. In my case, just tightening the screws fixed this. Later in my experimentation, I replaced the glass with a thing PC gaming mouse pad I cut in circles (2 layers did the trick) but that is another story...
I was considering breaking out the screwdriver as my gut feeling is that it is the glass.
Apr 15, 2021 at 11:58 AM Post #1,353 of 1,601
Strange the glass on mine is glued on rim... some sticky glue...no hard one..no play there even if you try to force it out will not move I think you need some force to break it loose
Apr 15, 2021 at 12:10 PM Post #1,354 of 1,601
anybody know if there is a solid fullproof fix for the glass issue? seeing as I can probably only get these for $100 used I don't want them to be a pain in the butt.... Might just stick with my Anker Q30 as my DD closed back tho as they are pretty damn good
May 1, 2021 at 5:17 PM Post #1,360 of 1,601
Jul 4, 2021 at 5:24 PM Post #1,364 of 1,601
Jul 9, 2021 at 11:16 AM Post #1,365 of 1,601
Just got this.
And it is definitely the LZ A6/mini (somewhere in between the A6 mini and the A6 in terms of timbre and uniqueness) of the headphone world.
:thumbsup:
