SincerelyAural
- Sep 2, 2015
It will most likely need to be replaced with a new pair at a fee (though a reasonable one from my experience).
It was my fault that I left it out, but damn does still hurt like.....
Now I got to send it in to see how much a reshell is
I feel the A6 lack of high compared to my oriolus. Do you find it normal? Could it be due to the FAW hybrid cooper cable?
I see what you describe. I listened lately a lot to the oriolus and switching to the A6 gave me this feeling. It may also depend on the module used.
I thought it was for the A12 the impedence adaptor.
They tune all of their Adel range out of higher impedance sources (ie stage equipment). Made a positive difference to both my U6 and also the U10 I am reviewing at the moment.
Pretty sure they confirmed earlier in the thread that u10 was not tuned for higher impedance sources. It will make a difference Becuase of impedance curves, but the u10 should sound as intended through low z sources.
Can you reference this? I may have missed the post, and can't find through searching. To me anyway, the U10 sounds much better with an impedance bump.
@moshen
The 12's were designed for the stage musicians, singers, and performers. The shure and sennheiser wired and wirless bodypacks, as well as other gear such as mixers, have higher output impedances.
The 10's are actually designed with the audiophile in mind. The 10's with the s1 module actually sound closer to what the 12's sound like with the b1 module.
The U4SE was designed completely for the audiophile as well.
