Poimandres
- Dec 23, 2009
You may not want to give it a listen if you don't want to keep it.
If I'm honestly that blown away by it I'll probably just buy a liquid gold since I want my next amp to be an endgame one. I actually think I'll be disappointed though because I doubt it will compete with other amps I've heard already though I think it will be very good for the price.You may not want to give it a listen if you don't want to keep it.
Frankly, I'm surprised that no one has posted anything like the following:
"Alex, I love the way the Carbon sounded at [INSERT_SHOW_ATTENDED_HERE]. I was wondering if you could tell me what cables you used so that I can get the same ones. Thanks"
Good catch on the AC14SE MKII. I would think that the 14 gauge cable would suffice as well.
Dr. Cavalli what are your thoughts? Also what is the maximum power draw on the LC?
Did you try the Ac14MKII? Haha
We've already established that the LC has a unique phase splitting function that enables SE (RCA) inputs generally perform as well as balanced connection. It was I that suggested to try balanced input anyway, but just in case your DAC may happen to have a better balanced section than SE; which may really be unnecessary. Also yes, the designer says that this amp amp does give better performance to headphones using balanced haeadphone cables.
So my understanding is that if the output to the headphone is balanced then there is a tangible difference to sound quality. Where as there is no difference if the input is balanced or not because of the phase splitter which effectively balances an unbalanced signal.
If you have a DAC you like, and it "only" has RCAs for output. Then don't sweat it.
On the headphone end, you need to have a balanced cable in order access all the amp's power.
I posted this in the other thread, some here may be interested.
Audio advisor has the Pangea 14se MKII cables on sale. You can get a 1.5 meter cable for 65. 75% off IIRC.
The Pangea uses the Cardas Grade One Copper
They also have the black mamba II rca cables on sale, should anyone be interested.
