Jeff Y
- Oct 18, 2013
Then where will you be.
Hoping for a second batch or a liquid carbon 2!
I'm in the upper 200's and I ordered within the first two hours. Even for a desirable limited edition amp or watch or anything, 500 is a whopping huge amount. Couple that with the fact that this is a relatively small community, I'm not surprised that some are still available. But they will sell out. Then where will you be.
What! LC2 already. Tell us the rumorsLC isnt even out yet but I have seen a couple of posts where people are going to cancel their order to free up funds for the new .... Since we ordered So Long Ago it may seem as if we have owned the LC for a while but have just not listened to it lately.
Gents, here's a post I made to the other Carbon thread.
Production run seems to be moving along well. Please keep in mind that we have been saying later in August or end of August. I have learned though, that things can still go wrong, especially the first production run of a new product. Let's just keep our fingers crossed that all the various production activities stay synchronized and all the parts continue to get here on time.
In the meantime, here are photos of the board for one of the last two pre-production units built. This is, almost exactly, what will be inside your Carbons. You can easily see the small smps transformer (yellow) and the larger components in the supply. There is a lot of capacitance in the supply. There is also a large gap between the HV section of the supply and the rest of the components on the board.
Input section is at the back right. Both amps and PS are on top and bottom of board. In fact, all you see in these pics is the left channel. The right channel is identical and on the bottom side. It is the small amps and the fairly small smps that make a balanced, totally discrete linear amp even possible in this size and flexibility and power output. The power inlet is only temporarily attached for test. In actual units it will be mounted to the back panel.
The relays in the center switch the gain and the ones at the back switch the input source.
This is very helpful. Out of curiosity, you say that the BW is not analytical and definitely EC, then talk about its clarity that is typically associated in analytical. Is this to say that this is a warmer more colored amp that doesn't get in the way of the detail? Could you clarify a little?
This post makes me really hot. This is just one side of the board? Just one channel? Haaaawt... I might have to take the case off and just look at the amp for a while. And then customize the case. I'm still putting racing stripes on.
Also, what are the little circle transformers off to the side for?
I wouldn’t say that clarity has a 1:1 relationship with analyticalness. I always thought that clarity meant little to no background noice/hum/hiss, when you listen you get just the music. I associate analyticalness with thin sound, lack of timber, and weak response from mid-bass down. But I did not mean clarity in the normal definition, but tube clarity. This is a little harder to grasp.
I never really noticed tube clarity that much until I heard the leviathan (OMG good), but since the tango output transformers are extinct I’ll never hear it again. All tube amps (woo 6, Valhalla 2, DNA strauss, etc ) I heard have it to some degree but I was never really able to put my finger on it (by the way the Liquid glass definitely has good tube clarity) until I heard the leviathan then it was clear (no pun intended). It’s like the someone took the sound and polished it so it has this shine that lets music sparkle. I know it sounds weird but it’s hard to describe. Another way I like to think about it is that solid state is like watching an imax movie behind a glass window. With a good tube amp the glass window is removed
I am very curious also, no one really talked about how the HD 800 pairs with the Liquid Carbon. Anyone care to share?
Actually a few of us have already said that we liked it with our HD800's...that's is one reason I bought it, BTW.
