iancraig10
- Jan 21, 2005
I found going up a size with the tips and shallow insertions worked better for seal.
If there are problems of getting them in, try putting a little water on the inside of your ears.
Hold the iem with the wire facing forwards or forward/down at 45 degrees. Line the tip up so that music comes into focus. Hold it there and then twist the iem backwards so the wire goes upwards. I leave my third finger in front of the wire to act as a spacer and use my other hand to slightly tension the wire further down.
Once the wire reaches the front/top of my ear, it's locked in with a good seal. Not a deep seal and no pushing in.
I do wonder whether some are only getting a partial seal so bass isn't what it is supposed to be. I'm finding the bass to be amazingly deep and profound with them now.
If the 'twist trick' doesn't work, try stretching the top of the ear outwards or even the bottom downwards.
'Tapolene' or water does help when first trying to get a seal.
That method of putting them on looks a bit finicky but it soon becomes second nature.
