And to all your suggestions on changing UI, we would like to change many small elements. But all of that needs to be done by folks at HiBy, so we can only report these things to them and wait.
Thats a shame!
Any thoughts on hooking the M2s to the new Q1MKII for trying balanced?
If you are owner of Shanling M2s and your device has problems with updating from firmware 1.1 or 1.2 to firmware 2.1, you can use this provided cloner tool to update M2s:
https://drive.google.com/file/d/0Bz_m_D8_7ujLZmNRSnpvaTFsVHM/view?usp=sharing
Warning: Process is little complicated, please follow the provided guide exactly and reach out to us, if anything is not clear.
Also, after updating to 2.1, this problem should never repeat.
PM me. We can have a "behind the scenes" conversation about what best fits your needs / wants.
I confirm, a great pair turned out, Shanling m2s & iBasso PB3, an excellent amplifier with a balanced headphone output, I've been using it for about a month, all my headphones sounded new.For trying Balanced (Amp only, no DAC), Ibasso has the PB3.
I's there a known issue when trying to connect to a S7 Edge via Bluetooth? I'm having a bit of trouble with HiBy link.
guys anyone using se846 or really low impedance iems with m2s?
i'm using lz a4 (16 ohm) and they sing beautifully. but I'm not sure that what happens with lower impedance.
I am, the m2s and se846 pairing also sing beautifully, to use your phrase. The combo is perfect for when I want to travel light.
Battery still get only 5-6 hours on low gain, playing flac and some dsd
