csimon
- Jul 1, 2015
Hi all,
I have a Mojo hooked up to a new XDP-100r, Wi-fi and Bluetooth off, I have disabled most of the extra programs and using UAPP playing a mix of 16/44 Flac files and DSD files. I get maybe 1.5hrs and the player drops to 30% battery remaining, and then dies about 30min later. Has anyone else encountered a super-reduced battery life when using an external DAC? (Or more specifically MOJO...)
Isn't it the case that when you connect a DAC via USB OTG, the XDP-100R will supply power to the DAC? The XDP-100R is therefore acting as a charger for the DAC. Or does the Mojo have a separate power supply?
I also believe that when using USB OTG, the host itself can't charge. Is that right? If so, isn't all this a fundamental design flaw in USB OTG?
