Hello. First time post here. I am getting ready to buy a $10,000 home system. Magnaplaner 3.7i with Parasound Halo amp and Project turntable. Is there anything I should be looking at different. I love Magnaplaner and the Parasound Halo seems vertical enough for me and future additions. Thank you
This is probably the wrong thread, but if you're spending $10k on anything audio you should probably really listen to it first. I've heard plenty of speaker systems well into 5 figures that sound like rubbish.
I was about to say the very same (advice) thing. Maybe mjphoto45 is going to do that.
IMO the ultimate way to test hifi gear is get it home for a demo, and if possible for a day or so minus the dealer present. The first 30 minutes can impress, the next 6 hours can take a different direction. Also before the home demo get some varied store demos of other gear at that price range. Forget the brochures, specs and such. listen to what is in front of you, then like I said, get a home demo.
Electrostatic panels can be difficult to position in the home to get the best out of them. Have to talked to other users on other forums about them?
http://www.avsforum.com/forum/89-speakers/1086093-official-magnepan-owners-thread-150.html
The above journey cannot be rushed, it is a drawn out process. If you try and speed it up you will be on the buy/sell bandwagon with losses along the way and frustration will set in.
The other thing IMO is take a hifi buddy with you for another opinion, someone who already has a decent system.
Don't forget buying used. Maybe those speakers you end up hearing can be bought used at 60% for example, and spend the extra on a better amp / TT.
Lastly, the dealer units you get to hear, don't assume he will have the best TT/Amp/Speakers for you are your price level. You will probably find a better amp (for example) somewhere else. Dealers tend to stick to a small group of manufacturers and push just those units. Sometimes they can go well together, other times not so good. And better performance may be had by trying other units elsewhere.
Actually
are you buying used?
Welcome to the world of high end audio! Good luck.
