nc8000
I didn't think wav had meta data at all
I don't understand what you are saying. What does "Tracks freezing with 0 bit 0 kHz " mean or refer to?
If you need to clatter the play/pause button to get the DX90 to play, it would seem you have a faulty unit. I'd get in contact directly with iBasso to see what they suggest re getting your unit fixed.
Firmware 2.1 positives....it resulted in the first time that my DX90 properly performed a media scan. It went without a hitch and only took about 8 minutes to complete.
Negatives, the device continues to experience several playback cut-outs and fade in's each hour (LAME VBR mp3's). C'mon ibasso, take care of that issue! The menu (scrolling) navigation seems much touchier and difficult, similar to the original firmware (2.0). Not sure about the sound....my initial impressions are that the original 2.0 firmware was cleaner and better balanced.
Genre, Artist, Album is the standard break down of every player I've known. However if you press and hold an artist you get a menu that allows you to play all tracks under that artist. Same goes for a genre
