- Sep 20, 2016
Stay updated on Effect Audio at their sponsor profile on Head-Fi.
Any suggestion for SP1000 -> Tia Fourte? Leonidas or Leonidas + Mars?
My review of the Ares II is up, it's a truly excellent cable
https://www.head-fi.org/f/showcase/effect-audio-ares-ii-iem-cable.22171/reviews#review-18796
What CIEM have you used? What DAP did you use?
Nice to see more cable reviews up!My review of the Ares II is up, it's a truly excellent cable
Do you feel the Ares II also tightens the bass, or does it add more quantity? Yesterday I got the tips for my Ei.3 universal reshell from Custom Art and so I finally got a chance to listen to the changes between the CIEM and universal fit. The sound has become a bit warmer and the bass does not quite have the impact of the custom fit. I also find that some of the clarity is lost. The Ares II might still work a treat, but I also think that the Eros might give a better result due to its hybrid design.
Thanks for the info and the generous offer! I am in the UK and use an AK70, but will look at buying a cable at some point anyway and don't mind relying on advice from Eric and Piotr for that.I found to to bring out a bit more body and impact personally. It'll likely bring out a bit more clarity like you want, so could be a good fit for your monitors. The extra presence up top was very welcome for my smooth sounding monitors.
One day I'll get the Custom Art FIBAE1 and test it with my multiple cables.
If you were in the UK, I could have lent you the cable at the cost of postage providing you have a source that takes a 2.5mm balanced cable.
The new FIBAE are being very well received, so that would seem like a great choice!
Thank you, very kind!Feel free to send a pm if you can't to try
I also have a single ended forza cable and a balanced toxic spc cable.
