Johnny1982xyz
The Beyer Balanced Cable has arrived, and a first impression confirms, what one would - hopefully !! expect: Balanced connection gives you this extra touch of transparency, or air between instruments.
Whether this is actually due to the cable & plug materials I don’t dare to comment; I understand this is more likely due to the improved electrical quality of the balanced signal, the amplifier respectively.
Does this cable lift the D7200 to a totally new level of performance ? Well not really, just more and better of those qualities that are already quite good…
My amp is the MalValve Head Amp Three, alternatively I may cross-check with the Audiovalve Solaris (both are tube amps, BTW.)
++ Regarding the “proprietary Beyer” connections of the 3.5 mm jacks: they fit perfectly well….
Regards
Urs
In my case with my home made cable (neotech copper wire is one of the highest quality on the market) rhe biggest difference is made by the balanced connection.
I have violectric v281... Going balanced it is doubled the mumber o used transistor...
Any tried headphone with this amp get a good improvement going balanced.
Stock cable of d7200 is quite a good cable ... But unbalanced...
