bigfatpaulie
Im sure it is, if you want to afford the cost
More than that, what I am meaning to say is that the Hugo2 is not a 'mini DAVE' by any measure.
Are you implying that the HE1000 V2 cannot be driven sufficiently by the HUGO2 for away from home use? My understanding was that the HUGO2 was more powerful than the HUGO1 and could drive HEK2??
No and I don't care. What I care is the SQ of HEk V2 vs BHSE+009 when both are driven by DAVE.
Stay updated on Forza AudioWorks at their sponsor profile on Head-Fi.
So once you have the HUGO2 for portable use would it make sense to move up to the DAVE alone or add the Blu2 Mscaler to the HUGO2? Wouldn't then you have 1 million more taps than the DAVE?
Hi @Rob Watts,
Another question that has been swimming in my head for some time if you don't mind.
So this is about the DX0 inputs on Dave and Hugo2 and home theater (HT) (and possibly implementing digital crossovers) and the volume control commands on the dx0-inputs.
For example, for HT a nice product would be a 5.1 digital pre-amp with 6 channel USB and HDMI inputs and DX0 outputs with volume control so that you could connect 1 Dave and 1 Hugo2 to create a 4.0 HT pre-amp or 1 Dave + 2 Hugo2s for a 5.1 HT pre-amp.
Is this possible i.e. controlling the volume control of a set of Dave/Hugo2s in this way using the DX0 inputs?
Thanks
//Martin
Trying to use optical cable from current iMac to DAVE.
can play up to 96 khz but cannot get it to play higher.
can someone show me how to get to higher res?
thanks!
I thought we were talking about optical?Are the option settings the same for optical and usb? You appear to be on the settings for the built in output ie the internal speakers. My screen shot shows what I get on USB..
Some optical cables are only capable of 96, and you have to use a better (that could mean shorter, or using glass fibres instead of plastic, or better end caps to the fibres) cable to manage 192.
