woodcans
- Aug 1, 2004
ZX1 > WM USB out > m8 > tu-05 > th900.
Awesome.
Awesome.
http://www.ebay.co.uk/itm/Sony-Walkman-NW-ZX1-NW-F880-series-only-Screen-Protector-PRF-NWH40-Japan-WoW-/281233032384?pt=US_Personal_CD_Players&hash=item417acb84c0
For now our best bet should be getting WMC-NWH10 first
http://www.amazon.co.jp/gp/offer-listing/B00FF086HE
http://www.ebay.com/itm/Sony-WMC-NWH10-Hi-Res-Audio-Output-for-USB-Conversion-Cable-for-UDA-1-Japan-/271310977023
Then add male USB to male mini USB adapter / cable
http://www.ebay.com.au/itm/USB-A-to-Mini-B-5-Pin-Data-Cable-Adapter-for-MP3-DC-/110925845691
http://www.ebay.com.au/itm/USB-A-male-right-angle-to-Mini-5-pin-left-angle-adapter-/140600089537
In the long run, someone might have the balls to disect WMC-NWH10 and figure out what the pin configurations are.
I did post something related before but so far nobody wanna take the plunge yet
http://www.head-fi.org/t/680853/sony-nwz-zx1-35th-walkman-anniversary-model/450#post_9858609
Basically WMC-NWH10 should be only thing available on the market right now with all pins required for OTG (USB Host mode) to work properly.
WMP-NWM10 only worked for charging and USB Client mode so most likely that won't be very helpful for an external DAC.
Thanks, kinda pricey though.
I buggered up the one I got from PJ so I had to get another.. I got a few bits of dust under the film, when I lifted it I tried to pick a piece of the underside but ended up having a fingerprint on it so it had to go... I don't see why I should fork out £500 to stare at my own fingerprint, it's just not cricket.
This is my first post. New to the forum, needless to say. Started this hobby about a year ago, and I have quickly reached the point where I really need a "support group," in order to bounce off ideas and to pick up experienced-based knowledge/information from others who share my interest.
As my first venture into the forum, I wanted to get your advice/opinions on my portable rig. I have been amping my ZX-1 with an RXmk3-b+ to drive LCD-XC and a couple of mid-fi cans (Sony MDR-1RBT and B&O H6). Fantastic sound signature, although I do wonder from time to time whether there would be a significant advantage in bypassing the amp on ZX-1. However, with my JH16 Pro, the hiss (white noise) from RXmk3-b+ is annoying enough for me to really consider another amping option that would allow me to enjoy both the LCDs as well as my CIEMs…I should be getting the new Roxannes from JH audio in a couple of weeks as well, so synergy with CIEMs will be quite important. I just never liked the PHA-1 and would like to avoid PHA-2 if I could, although it is probably the most seamless solution. Besides, I am not sure if PHA-2 can really properly drive my LCD-XC…I listen to a mix of ALAC and FLAC files with a decent selection of high res material.
Any suggestion/guidance on the following would be very much appreciated:
1) Is there a significant advantage in terms of SQ in using an external DAC with ZX1?
2) If so, which DAC/Amp combination would be the most suitable given my situation? If not, is there an amp-only solution that makes sense here, or should I just keep my RXmk3-b+ and get a separate, low output amp for my IEMs?
Many thanks in advance for your guidance, and I look forward to (hopefully) making contribution to the forum in the future.
As Sony states, I am getting 20-25 hours battery life from FLAC playback.
Also you're in Tokyo so Akema****e Omedetou Gozaimasu - there's a mini Tokyo HF group PM me off line if you wanna join .
