Penchum
- Oct 31, 2006
No problem. It is confusing at first.
The stock Zero comes with one "dual" Opamp (one chip) in the DAC section. It has two "dual" Opamps (two chips) in the headphone amp section, one for each channel, L & R.
The signal is first amplified/colorized by the DAC section and either goes out to the RCA's on the back for use in another amp, or goes to the internal headphone amp for further amplification. The headphone amp "colorizes" the signal further as it amplifies it to headphone levels. This is why you will see folks posting about changes in the SQ based on both DAC & headphone amp Opamp changes. In the case of the "single" Opamps like the OPA627BP's, it takes two "single" Opamp chips on an adapter, to equal a "dual" Opamp.
Does this help, or did I mess it up?
Originally Posted by Ok, after reading to page 20, I am kinda confused... I can't even think how to phrase my question. How many OpAmps are in the Zero? Like, how many can be replaced by something better? And what OpAmps should I get(for Prog Rock/Metal) for what part of the Zero(Meaning DAC and Amp sections)? This is probably much simpler than I am making it out to be, but I just got my self incredibly confused. |
