chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
why isn't anyone outraged that PS audio is charging $100 for $5 in parts and maybe 20hrs of engineering assume the EE is not that good?
Originally Posted by Jahn /img/forum/go_quote.gif Why does EVERY post have to be so scary? |
Originally Posted by Patrick82 /img/forum/go_quote.gif I removed it from the wall, listened again after 30 seconds, it was still too heavy. Waited 26 seconds and tried again, it was less heavy. Waited 42 seconds, it sounded much thinner, it was close to "home". Waited 52 seconds, it was even thinner and there was sibilance too, bass was gone! Waited another 52 seconds and it didn't sound different. It took 2 and half minutes for the noise to build up after removing the Harvester. I'm able to listen to my system again without headache. I'm not planning to put the Harvester back. With 2 Harvesters I can only listen to my system 5 minutes at a time. But without the Harvesters I can listen all day without fatigue! |
Originally Posted by Patrick82 /img/forum/go_quote.gif Then I turned off projector and turned on my $200 Acer LCD screen. Wow it looks cleaner and more 3 dimensional, it's like I have upgraded to a new display! It's both blacker and whiter at the same time, everything jumps out more. The box where I'm writing right now looks deep. Everything looks more separate. Colors look better. The black level still isn't acceptable for movies, but it's better than before. |
Originally Posted by Chinchy /img/forum/go_quote.gif Are the effects additive? As in, if you add multiple Noise Harvesters, does everything jump out more? I wonder if it's possible to obtain an almost 3d-like projection by adding 5-15 more noise harvesters? |
Originally Posted by The Monkey /img/forum/go_quote.gif Really my favorite yet (see sig.). Now Patrick, you said that you were happy with your system despite all attempts to find something wrong. What made you decide to go for the Harvester in the first place? You knew the potential for crazy bass and yet you plunged in headlong. What gives? I think it's that you LIKE extreme bass and just won't admit it. |
Originally Posted by The Monkey /img/forum/go_quote.gif I think it's that you LIKE extreme bass and just won't admit it. |
Originally Posted by Jeff Wong /img/forum/go_quote.gif Patrick - If the difference is this significant (I did not find them to improve things much, if at all, in my system, which already employs a variety of power conditioning), I wonder if you may have some imbalances in your system that went unaddressed. After all, we're talking about the electricity before even getting to your components. You might want to plug in those Harvesters and figure out what else in your system might be creating excessive bass. |
The Feet of Silence made the most positive difference. The contrast with Stillpoints was instructive - using the Stillpoints the music lost its bloom, and sounded overdamped and constrained. The Feet of Silence let the music breathe mone freely. |
