1. Improved M3U playlist import function.
2. Enable a second tap on homepage album artwork to have a full artwork view.
3. Enable exFAT Micro SD card to be used for next firmware update.
4. Fix the power off bug when using the USB card reader mode and USB DAC mode.
They do other things also. Lol It is part of the job to listen also. You would not want to breath the air here. I have read it is like smoking 2 packs of cigarettes a day.
The low level thump heard when pause play is pushed is part of the CS4398 hardware. It can be heard on other daps to a greater or lesser degree that use the CS4398. Firmware will not change this.
Wow, was doing some banking and noticed a deposit from the DOJ/FTP (Full Tilt Poker) LOL! Only took a couple of years. So of course I had to spend some and ordered the DX-80.
Thanks Paul! The M3U playlist import function is important to me and I'm glad you all are working on it. Any specific detail you can provide on what "Improved" means? Can I sync M3U playlists now?
Btw, I did buy a DX80 and I love it. Sounds and plays beautifully! Nice work to you and the gang.
Just wondering, so if that was the case, why was it not explained sooner if it is known on all CS4398 hardware? If it was there from the beginning during testing, wouldnt it have been better to let customers know instead of having them believe a future firmware update could fix it? Ever try it with really sensitive iems? It is not pleasant at all.
