goldendarko
- Nov 9, 2013
If it's at the top of twisters list it must be really good. Just wondering what your favorite source pairing was overall though twister6?
When the new ones come in I will take some intimate portraits of the tips just for you...
Anyway Ken should take noted for incoming new design in future, we already high lighted the shell edges should do something softer cornered.
Otherwise would be hurt those smaller ears.
There is quite sharper like a knife can easily cut though internal side of ears, it there was improper wears for longer hours.
Thank you
Well, I wouldn't go as far as "sharper like a knife" If that's how your pair feels, than you got a cool weapon to swing around :evil:
Btw, I don't have big ears, probably average or a bit smaller. And, as I mentioned in the review, it's all eartip depended. I'm not sugar coating anything, people tip roll to find the best fit and isolation, while with Andromeda for some the correct eartip selection will also mean a comfort of extended wear. It took me awhile to find the right pair, but it's not a show stopper.
Well, I wouldn't go as far as "sharper like a knife"If that's how your pair feels, than you got a cool weapon to swing around
Do you happen to have the less powerful amp module for the X7 to test with the Andromeda? Curious if the X7 could be a silent option. Thanks for the review!
What eartips did you eventually go with?
That is what she said.Thank you! I love deep insertion (yeaaa...) and the Jupiter hurt my ears with stock tips.
Andromeda boxing here -- not my best effort. What it really needs to say about the cable is that it is ergonomically like a regular IEM cable but using higher quality wire.
I left them for about a day running pink noise and they are every bit as impressive with acoustic music as they were when I first tried them in Tokyo. They are tonally very like the open-backed MrSpeakers' Ether with sparkling highs and a fair bit of mid-bass in my ears.
I'm presently running them from various portable devices as well as amps from an Yggdrasil or Mojo.
