m-i-c-k-e-y
SuperVOX, their new Hybrid Ladder D/A Converter
I'm a little concerned about all these new products without finishing the old ones first
In the picture I see the Super Hub
When I learnt there were different versions of the HUB due to availablity of some components, I can specultate on two things:I'm a little concerned about all these new products without finishing the old ones first
Yes I ended up doing that. Thank youNon ha bisogno l'USB dal NUC con Roon. Basta collegare con LAN.
Router (via LAN) -> HUB (Ingresso: LAN, Network: Roon Uscita: via I2S) -> VOX (Ingresso: I2S)
Buon divertimento!
I have the same issue of the clicking when changing resolutions. I don’t think it has been fixed. I am on the latest firmware fyi.Everything works fine the only thing is that when I change track on Roon to different resolution Vox keeps making relay clicks. I think you have already talked about this
Sì, ho anche aggiornato tutto all'ultimo firmware.Ho lo stesso problema del clic quando si modificano le risoluzioni. Non penso che sia stato risolto. Per tua informazione ho l'ultimo firmware.
Yes also I updated everything to latest firmware.Sì, ho anche aggiornato tutto all'ultimo firmware.
Pensavo di aver lasciato che impostando un UPSAMPLING il VOX rimanendo sempre alla stessa risoluzione non facesse più il Click, ma invece lo fa comunque.
Dovrei aggiungere che come suono per me ottengo il massimo a 705/768K
I don’t have the hub so cannot comment on that.Yes also I updated everything to latest firmware.
I thought I read that by setting a UPSAMPLING the VOX always staying at the same resolution would no longer do the Click, but instead it does it anyway.
As sound quality by me I get the best at 705/768K
@ThanatosVI you're not the only one. I really hope Rockna WLS will get finally all promised features and will not be killed like Audiobyte products before delivering 100% of functionality.I'm a little concerned about all these new products without finishing the old ones first
