Audiobyte Hydra Stack: Hydra.Vox + Hydra.Hub + Hydra Zap
Jan 26, 2024 at 11:05 AM Post #827 of 916
My current amp is Cayin HA-3A via XLR, HE1000SE headphone. I like it much more than solid state.
The RCA outs of Vox are connected to speaker amp (300b tube based), that I prefer as you do.
Jan 27, 2024 at 3:54 PM Post #828 of 916
Good evening everyone. Yesterday I ordered an Audiobyte Superhub which I will connect (I2S and USB) to my Hydra Vox+Zap DAC and alternatively to a T+A DAC200.
Jan 28, 2024 at 6:15 AM Post #832 of 916
how much is the super Hub?
Hi, I don't know,I wanted to buy Hydra Hub but it is out of production.The price with Rockna 60 cm I2S cable €2,8k
Jan 28, 2024 at 6:16 AM Post #833 of 916
Jan 31, 2024 at 8:18 AM Post #834 of 916
Have anyone disconnected the headphone amp section of Vox from DAC section and power? I don’t use it, meanwhile it makes a lot of heat. Or there is no other way but asking the manufacturer?
Mar 9, 2024 at 7:44 PM Post #836 of 916
Great, let us know when it arrives how it goes 👍
Hi, the Superhub streamer was delivered at the end of February and today I started using it thanks to some indications that suggested using minimserver and mconnect >upnp input. Everything OK sounds great connected to the Hydra Vox DAC.
Mar 11, 2024 at 11:39 AM Post #837 of 916
Hi, if you put VOX in DSD direct on the app the headphone section is disabled.
It might be helpful for some, but I never listen to DSD. My CDs and local flac files all mean PCM. That’s why I would prefer the hardware solution.
Mar 12, 2024 at 4:07 AM Post #839 of 916
Ha ha ha people have some "UPGRADITIS"...give us some headsup after. Functions, upsampler/format converter etc.
Will wait for the new VOX and then will decide.
