MadMan007
- Oct 17, 2008
Um, no. The whole point of BNC versus RCA-style S/PDIF is that it avoids impedance mismatch inherent to RCA S/PDIF so the length will make no difference. (This is aside from the argument that the shortest cable is best that Dan Lavry makes.)
Originally Posted by IPodPJ /img/forum/go_quote.gif Short/Long not even an issue. I have no need for an 18 foot cable. I only need 4 - 5 feet. But the 18 footer sounds better which is why I use it. It's coiled up. Center imaging is more precise and notes are less blurred. It affects sound because of signal reflections that can be caused by impedance mismatch. But even if you are using 75 ohm BNC connectors on both ends, the cable length does make a difference. Try it for yourself. You can always return one to BJC or sell it. |
