I agree. My DHC pure copper Complement cable made my HD800 sound smoother without loosing and spark in the top end
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
Originally Posted by 00lunar /img/forum/go_quote.gif Edit: Done some research, and i guess that the best option for me is hiFace toy with denend rca cable and then dac ref1 and phoenix. Am i right? Anyone knows if i should stick to hiface rca, or should i pick bnc? i won't lie... sq is at 1st place here. |
Originally Posted by haloxt /img/forum/go_quote.gif If you're going copper maybe you could ask Kingwa if he can make a cable with his 500 meters of double helix nucleotide internal wiring |
Originally Posted by Currawong /img/forum/go_quote.gif It's often cheaper to have a 4-pin terminated headphone cable built than a 2x3-pin XLR one, especially if you have a TRS adaptor made as well. Ignore the guage of cables. 18 AWG is speaker cable. Headphones don't require the same current speakers do, so it's just crazy to have a cable that thick IMO. My suggestion is to buy two HD-800 cables after you've listened with the headphones for a couple of hundred hours: One copper and one silver, but buy them second-hand, and sell the one you like the least. |
Originally Posted by haloxt /img/forum/go_quote.gif IMO you should decide on cable after you have listened to whatever dac and amp you buy. I think this is especially true if you get something as neutral and uncolored as ref 1+phoenix+hd800, less so if you decide to get one of audio-gd's more musical dacs. You could reterminate your stock HD800 cable to XLR and seeing what you'd like to improve/alter with a cable upgrade, and I highly recommend going 4-pin xlr route since 2x3-pin xlr is not convenient and needs to stop being the standard for balanced headphones. |
Originally Posted by haloxt /img/forum/go_quote.gif It's been a while since I looked but I believe there's not much to choose from with 4-pin xlr, the majority of xlr connectors are 3-pin, popular with pro-audio equipment. Here's three from Neutrik, I haven't really tried to find out what different contacts do to sound quality, so you'll have to ask someone else for advice there. NC4MXX 4 pole male cable connector, Nickel housing, silver contacts NC4MXX-B 4 pole male cable connector, black metal housing, gold contacts NC4MXX-BAG 4 pole male cable connector, black metal housing, silver contacts |
Originally Posted by haloxt /img/forum/go_quote.gif There's some 18 awg aftermarket cables for hd800, so 22 will fit, and I believe double helix nucleotide is actually 24 awg not 26 awg. I don't have enough experience to give you advice on cable sound signatures, but from what I experience and read, cables will often color the sound, possibly in a way you don't like. |
