Well, here's what I got in the mail today!
So the first thing I had some FUN with was figuring out what combo of buttons needed to be pressed to get output to the Headphones. Once you figure out how to work the buttons it starts making music!
An improvement is that he attached the "Note" on the front with Scotch tape. Thanx KW! No Goof Off needed today to get the stickers off.
A departure from the Compass. The Chassis is stamped Steel rather than Battlsship thick Aluminum like the Compass. He is not heat sinking to the Chassis as in some of his other gear, so I don't know if that had something to do with it or not. But I miss the Compass case.
The Front Panel is the same as the Compass, 8mm thick AL. There is no Opmap in the Opamp socket in the default config. In my opinion the Opamp improves it a lot. Sounded a little Flat without it. I have a SUN HDAM in there at present.
I have a few modules to try out as well here, so that will be part of the FUN!
Initial impressions with the SUN: Bright and Bassy as one might expect from the SUN. But in a FUN in the SUN kinda way. Strange thing is, I never thought the Compass showed the SUN off that well. Didn't think much of it in the Compass. Maybe it will show the MOON well too. I didn't like it either in the Compass.
So, after just a little listening time, sounds interesting and I like it so far. Tried it out with Beyer 770-80 Pros and HF-2s so far.
Additionally the Gain seems a little Low without the OPA in place. I got a bunch of Chip OPas I can try as well. I think I may drop a LT1364 or 4562 in there and see what happens. I also need to extricate the Earth out of my Zero or Compass for it.
EDIT: I just "spoke" with KW about the OPAamp not being in the socket. It needs it. I think he was assuming I would use one of the HDAMs I already have. Also he told me the case is AL not steel. But it is not the THICK AL a la the Compass.
