UtzY
- Dec 21, 2006
2010-01-02,UtzY
Hi,
I have a question if you don't mind.
From the pictures I see that the new Fun appears to be similar in technology with C-2C, I have to ask you directly... what's the difference between the two? (What's better and why?)
In specs you stated that the Fun has 3500mW/25 ohm
The C-2C has only 560MW/25 ohm
What transformer have C-2C and what power consumption? From the pictures I say that it is quite similar.. and from the specs I understand that the Fun is quite better.(better acss modules?)
What amplifier(alone without DAC) do you recommend? And why?
Dear Sir,
From the pictures I see that the new Fun appears to be similar in technology with C-2C, I have to ask you directly... what's the difference between the two? (What's better and why?)---------The ACSS modules is better in FUN, but C2C is applied class A power supply,MOS output stage, so total C2C is slight than FUN amp.
The C-2C has only 560MW/25 ohm--------------------Because C2C is applied class A PSU, , and 560MW is enough for most 25 ohms headphone.
What transformer have C-2C and what power consumption? From the pictures I say that it is quite similar and from the specs I understand that the Fun is quite better.--------------C2C is applied 50W R -core
What amplifier(alone without DAC) do you recommend? And why?-------C2C or ROC or phoenix. If your source is good enough, they sound neutral, so they can show you how good or how bad are you're recordings.
Kingwa
Hi,
Dear Sir,
Kingwa
