I was just saying your comment as using a 100 Ohm resistor in series is not the best way to make an adaptor was a little soft. Since that would make a 150 Ohm load on a 16 Ohm output which, at speaker level power would put a larger strain on the output transformers (translation more heat). If they weren't designed to handle the heat than you would ultimately hurt the transformer, which would lead me to say BAD IDEA as opposed to your saying not the best idea, hence too soft.
In one of my previous post I had also recommended that the person should use a 20 Ohm Resistor in Parallel (or Shunt as you have said), ideally to get a better match to the tap, the result would be that most of the power would dissipate through the resistor.
