This sound amazing. A complete matching stabilized set would be amazing.Soon enough Zach is going to have to put together the deluxe ZMF package - ZMF headphone + Amp + cable + salire + box + robe + slippers + pipe...only thing missing is the ZMF DAC....
ZMF Spring Limiteds, CanJam NYC and Estimated Release Schedule for Caldera Closed and BOKEH Open!
- Thread starter zach915m
jsabini1
The Stabilized sets are up: https://shop.zmfheadphones.com/collections/stock-headphones
Also part of this batch will be Stabilized Salire's, Maple Burl Wood Cases, and some special matching cables courtesy of @BooUrns. The photo's and pages for those will be up tomorrow! Here's some pics of the Salire's, Cases and Cables.
That one Salire looks like it's spalted maple? Incredible! All of it looks amazing, truly. I wish I'd already won the lottery!The Stabilized sets are up: https://shop.zmfheadphones.com/collections/stock-headphones
Stabilized pads! They'll last forever!Matching stabilized wood pipe, with audiophile tobacco.
Toonartist
Formerly known as dAndis67
Just to add, it's the Aqua 2 version that's 47uF and ok in a standard Aegis, the original Aqua had a 4uF requirement which isn't.... just in case anyone sees them up for sale second hand and is tempted. Sophia Electric only have Aqua 2 for sale so alls good there!Product page for the mesh plate states 10uF. This is due to inrush current on startup, bigger cap, higher inrush current. However, there are other variables in play that are specific to the amplifier in question, namely the B+ AC voltage on the rectifier plates and the power supply impedance. So the cap value isn't a hard and fast rule, they give a maximum value assuming the user is going to operate the rectifier at its maximum specifications, which Aegis does not do. So, can either play it safe and go with the spec sheet, or reach out to them for further clarification. Safe way is to not use the mesh plate 274B and get their Aqua version which can handle higher inrush currents.
@meomap
meomap
Yes. I bought Aqua II version last night.
Version I sold out anyway.
Thank you ALL for the advices...
Time for Enjoyment with another new Toy...
Need to compare Aegis vs ALO Studio-Six vs WA6SE vs PL HP tube Int Amp.
OnlySoMany
These three are beautiful.....
OnlySoMany
If ZMF and Chord Electronics ever teamed up, God help us all.....Soon enough Zach is going to have to put together the deluxe ZMF package - ZMF headphone + Amp + cable + salire + box + robe + slippers + pipe...only thing missing is the ZMF DAC....
- Oct 19, 2008
Here's some of the actual Salire's that will be available. You also will be able to "add on a matched stabilized Salire" to the headphone if you'd like. I also am including some of @BooUrns matched cables that you'll be able to add on as well. Because of the sleeving and wire used (Palladium, 2K, Verite Silver) they can only be made with XLR and 1/4" ends.
ZMF headphones hand-crafts wood headphones in Chicago, USA with special attention to exceptional sound and craftsmanship.
Stay updated on ZMFheadphones at their sponsor profile on Head-Fi.
- Oct 19, 2008
Awesome work! I thought I was going to sit out this round...but one of those salires + matching cable might make its way into my cart tomorrow.Here's some of the actual Salire's that will be available. You also will be able to "add on a matched stabilized Salire" to the headphone if you'd like. I also am including some of @BooUrns matched cables that you'll be able to add on as well. Because of the sleeving and wire used (Palladium, 2K, Verite Silver) they can only be made with XLR and 1/4" ends.
Beautiful. What will the pricing be on the Salire's?Here's some of the actual Salire's that will be available. You also will be able to "add on a matched stabilized Salire" to the headphone if you'd like. I also am including some of @BooUrns matched cables that you'll be able to add on as well. Because of the sleeving and wire used (Palladium, 2K, Verite Silver) they can only be made with XLR and 1/4" ends.
Other plants might pair better in a music listening pipe imo. . .
Where are those stands on the site??? I NEED that purple ont to match my new Stabilized atrium I got from you!Here's some of the actual Salire's that will be available. You also will be able to "add on a matched stabilized Salire" to the headphone if you'd like. I also am including some of @BooUrns matched cables that you'll be able to add on as well. Because of the sleeving and wire used (Palladium, 2K, Verite Silver) they can only be made with XLR and 1/4" ends.
Also is a stabilized Aegis in the near future....?
