I read sometimes it works, sometimes it doesn't. Figured I had nothing to lose. It was a crackling noise like crinkling wax paper or tinfoil, something like that. I was home today getting my sprinkler system fixed so my Pendant was on all day and I was listening most of it. Lucky me! No noise at all after cleaning the pins.
Be sure to clean your sockets too. They can also cause issues with spurious noises if they get really dirty. Pipe cleaners work great for octal sockets, and the things below work great for noval sockets. Just be sure to spray the cleaner on the applicator (not directly into the socket).
I though this was kind of cool. . .I have collected all the earliest versions of my current favorite tube, and here is the evolution of the Hytron 12BH7 becoming the CBS 12BH7A.
Hytron 50' (Raised D Getter), Hytron 51' (Angled D Getter), Hytron 52' (Angled Square Getter), CBS-Hytron 53' (Angled Square Getter), CBS 58' (Raised D Getter)
@Wes S have you ever tried a Raytheon black plate triple mica windmill getter 5814? I think I remember you saying the double mica versions were better????
They’re a little easier to get than the double mica. They can be found pretty much anywhere. I’ve been wondering about this one as well. The triple mica design should reduce noise which might contribute to more detail.
A tube I can highly recommend for the tone heads here (with adapter) is a Ken Rad Black Glass VT-231. The mids are very clear, the bass is super dynamic, there’s smoothness and welcome tone in droves but don’t expect the most expansive stage or detail. If you truly want more clarity I would suggest the Ken Rad Black Plate Copper Cathode VT-231. All you need are 6SN7 to 12AU7 adapters. I can’t imagine clearer mids. Vocals are as sharp as a knife and are very easy to follow along. Same great bass and no sharp treble. Ken Rad makes some great tubes particuarly if you prefer tonality over absolute detail.
All else equal (usually not), would not a triple mica tube sound better than a double mica equivalent because of: taller plates and greater structural rigidity?
In terms of micro phonics yes but the double micas are older which the general rule of thumb is that older tubes sound better (better cathode material, better vacuum etc.) That may be the case with these tubes. I can’t really comment on them as I’ve only heard the double mica and found them a bit too forward for my tastes.
After owning these for a few years and only using them for an hour or 2 in a LP, I finally tried the Tele G73-R in my BB. It is a very nice tube, top to bottom with great detail retrieval and no brittle top end. There is an almost eerie realism on many recordings.
I can see why some folks on the Riviera AIC-10 site are getting excited about this Telefunken.
LOL! Nice try, but not gonna bite, and especially for that kind of money. Those AIC-10 guys with their Abyss headphones chasing transparency and detail, can have them all (and can afford them).
I am fine with this one (at $25 a piece), with it's weighty notes, euphonic texture, holographic stage to die for and "thereness". . .what else could one want?
Since the maniacal 'Wes S Tubes, Inc' has single handadly bought any and all of the available worldwide stock of the mythical Hytron, what is a mere mortal to do in procuring this unicorn tube?
I am fine with this oneall of these (at $25 a piece), with itstheir weighty notes, euphonic texture, holographic stage to die for and "thereness". A monopoly on great sound …what else could one want?
