ZMF November 2024 // Schedule - Announcements and MEGATHREAD!
Dec 12, 2024 at 2:16 PM Post #1,756 of 2,882
I wonder how this compares to my V281LE or Headtrip II.
The V281 LE comparison would be interesting, though the Vio is a much more versatile amp in that the DSHA-3FN would not adequately drive something like a Tungsten or Susvara. But it wasn't designed for that kind of application.
I can say it sounds superb with my ZMFs and Focals (which it was designed for, hence the F). It's a flexible amp in that it also sounds excellent with Senns, and surprisingly with the Rosson I have as well.
Dec 12, 2024 at 2:22 PM Post #1,757 of 2,882
My other wish is that Christian would release another version with the nickel cores instead of amorphous cobalt as well
Dec 12, 2024 at 4:33 PM Post #1,758 of 2,882
Beautiful!
The headphones aren't bad either :wink:
But honestly in the picture the headphones look like they have kind of a holographic effect maybe depending on which angle you are looking at them.
Chatoyance
Dec 12, 2024 at 5:19 PM Post #1,759 of 2,882
Dec 12, 2024 at 8:45 PM Post #1,760 of 2,882
Please excuse my ignorance but what is the difference?
Dec 12, 2024 at 9:32 PM Post #1,761 of 2,882
I haven't heard the nickel version but some ECP DHSA3F owners preferred the nickel over the amorphous for tonality
Dec 12, 2024 at 10:15 PM Post #1,762 of 2,882
If you want in depth info on this amp, and various views on the different Lundahl cores the thread on SBAF is quite informative, which I found interesting as an owner of one.
I do think sonic differences between the cores will also depend on your chain, headphones, and preferences. Christian (CeeTee) explains why he chose the amorphous cores, and I think it makes sense. It is also possible that the differences in the core preferences are a bit like pad preferences for ZMFs.
I think the amp sounds really excellent in the current configuration, but I never heard the OG amp or compared cores.
https://www.superbestaudiofriends.org/index.php?threads/ecp-dsha3f-ravenswood-3f.7382/
Dec 12, 2024 at 10:38 PM Post #1,763 of 2,882
Never heard one of these. I'd love to compare it to an Enleum amp23R, which is what I would consider the best solid state headphone amp I've heard to date.
It was a standout for me hearing the DSHA-3FN at CanJam SoCal. I auditioned with my Caldera, which some people don't recommend and recommend ZMF dynamics instead. Regardless, it was a beautiful sound. It was connected to a Holo Cyan 2 DAC.
The Enleum Amp 23R is different in that it sounds warmer overall and more intense in the bass. But the DSHA-3FN sounded unbelievably open yet pleasant. Unlike any other solid state I've heard. It made me want to get one and have the Amp 23R and the DSHA-3FN be my two complimentary solid states.
Dec 12, 2024 at 11:49 PM Post #1,764 of 2,882
Interesting...I wonder how does the V281 LE stack up since thats my current go to hugh end SS amp.
Enleum Amp 23R or DSHA-3FN, hmmm...
ZMFs need new amps to play with.
Dec 13, 2024 at 12:12 AM Post #1,765 of 2,882
I believe the Enleum is more suited for planars, although I could be wrong about that. 3FN is definitely made for dynamic drivers and seems like a great choice for Focal, ZMF, Grado. I spent a long time debating whether to upgrade to the 3FN or a Mass Kobo 433. I have the 433 on the way since I got a really good deal on one from a user here, but 3FN definitely seems like one of the best small solid state amps out there for dynamic driver ZMF, possibly the best depending on preferences
Dec 13, 2024 at 12:53 AM Post #1,766 of 2,882
Hmm .... my interest is also piqued. But with my ZMFs, I usually go the tube route anyway. Granted I have not heard the DHSA-FN, but given the grunt and flavored sound of the Vio, I doubt you are missing out on anything. Further, from specs, the 281 should be super versatile given the range of gain (across planars as well). Interestingly enough, I enjoy the Atrium on the 281LE more than tubes but I like the Caldera on 300B tubes. Kind of upside down.
Dec 13, 2024 at 1:26 AM Post #1,767 of 2,882
I had a Mass Kobo 433 but couldnt justify keeping it since I had a Wells Headtrip II and V281 LE and since both complemented each other, it made the 433 redudant. Though it was great amp. Neutral leaning to the side of analytical.
V281LE versatility is the reason why I kept it. 4.4mm out. Check. Pre-out to stereo speakers. Check. Ability to swap opamps. Check. Heck I may pick up another one because its that good of an amp. AC is great, Caldera is good, but the Bokeh sings on the v281LE.
Where are all the November drop pictures guys?
Dec 13, 2024 at 8:01 AM Post #1,769 of 2,882
+1 to DSHA-3F with ZMFs. Also, if you want to try tubes for cheap, definitely check out the Shortest Way 51+, which also works great with my ZMFs.
Dec 13, 2024 at 8:23 AM Post #1,770 of 2,882
I need to demo this to see if I should add it to my evergrowing collection of amps.
At CanJam a year ago, Zach had an older CFA 3FN in the ZMF room. I had just listened to it (and thought it sounded great!) and Zach asked me if I liked it. He said that he loved it and that it has a unique sound he has never heard from another solid state amp.
