Firstly, thank you all for the excellent replies. Amp picking is sometimes even more convoluted than picking a headphone. I have heard the gamut of impressions from:
- “tubes are best on brighter headphones”
- “tubes make the Aeolus too dark”
- “hybrids are not worth it, just get a tube”
- “tubes measure terribly, just get a solid state”
Is the Darkvoice/LP good for the Aeolus only with specific tubes? Does it make it too dark? And some amps have way too much gain— is this a problem with the LP or Darkvoice?
This is a very good point IMO....all of the above are true...and false IMO. Some tube amps re indeed quite "syrupy" and not a great match for the Aeolus, some are designed differently. The same with hybrids...some are better than others, and there's always the matter of preferences. I always say "One man's detailed headphone is another's "too bright" headphone. It can be quite a journey.
The bottom line is, I don't think there's an easy answer. It really does depend on tha amp, as well as the rest of the chain (DAC & headphones, possibly as well as wires depending on what you believe). What
@haasaaroni is saying is quite right...the synergy can be key. Also knowing what your preferences are obviously and trying to build your system accordingly.
The best bet is usually to find someone who reviewed something you're familiar with. If their views match your own you might be able to glean something useful from their experiences, but that's not always so easy to find. If you have specific questions we all do what we can to answer...hopefully in a helpful way.
The good news is that the Aeolus sounds good from most amps IMO...some are definitely better than others, but I haven't heard Aeolus sound actually bad on anything (yet...of course YMMV). If you find a good rapport with someone who's opinion you seem to agree with/trust try a PM & see if you can get any more info.
And please let us know what you decide! lots of luck...
Edit: I realize that I didn't address the measurements issue. I do think it's true that tubes in general measure less favorably than solid state amps, but for whatever reason I don't think that there is (usually) an audible...penalty if you will. Lots of theories abound regarding the reasons, but to my ears a good tube amp often beats a good SS amp.
