The Msop switches frequencies and doesn’t just convert voltage. PWM is how the Data travels.
MSOP is a form-factor, I understand you mean DC-DC convertor, MP1542 in stock?
It utilises PWM indeed, but it has nothing to do with data or its travel (that would be I2S bus exclusively), modulating width of pulses allows it to maintain constant voltage output under load by increasing width of pulses (thus providing more current) or decreasing if current is not needed thus making them more efficient. There's usually two FIXED frequencies at which they operate: 700kHz for lighter loads and 1.2-1.3MHZ for heavier loads (when high current output is required).
This unfortunately pushes a bit of noise into analogue power supply that then is filtered (attenuated) by a combination of inductors (T1 uses small SMD inductors on DAC/LPF daughtercards by the way) and de-coupling capacitors, removing AC noise as much as possible and making power supply DC.
DSD does not utilise PWM actually, but PDM, Pulse Density Modulation, the difference is that pulses does not change length as with PWM, but same length pulses are placed more densly for higher voltage (well, actually current hence current output DACs such as 4499 or ESS family, it's simply more straightforward to implement).
Regardless, these are completely independent systems and there is no digital data feed into DC-DC converter at all.
(Digital) Bjt outputs are 250 ma there my be a conversion going on therefore between a digital input into and and analogue output Bjt.
There is no data conversion taking place in output transistors either, as they belong to analogue section of T1 as per block digram above and all the
Digital to
Analogue
Conversion is performed by
DAC and DAC only. BJT transistors are not DACs, they don't perform digital to analogue conversion, DAC does.
To reiterate and as per T1 block diagram posted earlier: digital data is supplied to Digital to Analogue Convertor (DAC) via I2S interface, is converted to analogue domain and from this point onwards (being DACs analogue output pins) all the way to headphones signal is analogue (including input of transistors), pink background in the diagram.
If so there is an advantage of playing DSD files over PCM.
Sorry, I don't understand, can you speak more clearly please?
I suggest reading a wikipedia article on DC-DC converters (not to be confused with DAC converters), I'm sure there is one there and it may help to clarify what DC-DC converters do, including the fact that they are purely analogue devices converting between voltages.
I disagree that there’s audio advantages converting to DSD. They sound better in my opinion!
Fair enough, no argument from me.
