HeyManslowdown97
Regarding DSD, I have found the DSD pro to process DSD files a bit strangely. If I convert a DSD to Flac which is lossless so it should sound the same, the DSD pro plays the DSD louder, while they sound exactly the same on my desktop. That might account for your perception of DSD being better, loudness is invariably interpreted as "more clarity" etc.
No! It is entirely different way the file is a processed. One is streamed with more information on one bit and the latter PCM (Flac) depending on resolution is generally 44/16 that means it streams at 44.1 in 16 bit resolution. It’s not the same sampling rate nor process. You actually the opposite you have lower the dB either -3 or below when converting PCM to DSD. I honestly don’t know what you are talking about it being played at a higher volume; that’s actually how they normalize many mp3s by jacking up the volume. If you played dsd at PCM red book -0.1 it would clip on the peaks in many recordings!
The DSD sounds fine and maybe they convert the Native files and trick to player as in DoP. The player believes it’s in PCM container but that’s a longer more older method process not used in many modern dacs and requires a lot of cpu power.
Moreover, many jazz enthusiasts (myself included) and recording studios favor DSD over any other format. They like DXD which is PCM in higher sampling and higher resolution. That’s why you buy a dac with chip like the akm4497 and that’s why they advertise it to play DSD NATIVELY and PCM at up to 768 kHz PCM at 32 bit.
From the offical Akm page of the Ak4497eq:
Supporting High Resolution Data
The first in the industry, a 22.4MHz DSD input is supported. The digital input supports up to 768 kHz PCM and 22.4 MHz DSD (Direct Stream Digital), recreating high-resolution sound that is as close as possible to the original acoustic source.
● Application
High-end Audio, Professional Audio, AV Receivers, CD/SACD Players, Network Audio, USB DAC’s
It’s in the description. Not sure why people buy this player or any dac with the akm4497 when all they play on them are mp3s. There are better mp3s players for that with better apps like upsampling the files to play at CD quality.
https://www.akm.com/akm/en/product/datasheet1/?partno=AK4497EQ
