ozkan
- Nov 1, 2012
OH MY GOD *CHILDISCH ON*, I dont know what I DID, BUT I GOT THE BEST SEAL EVER!!!!!
That is a bit difficult, But GUYS you will FREAK OOOUUUT!!
You have cut the Standard tip in the Half and put it over the Bore & Then use The UE900 Tips L, for small Ears M, and the Put it over.
It does not work with your hands you Need to put between the Tip Hole tweezer to make the Hole big enough to cover the bore of the In Ears with the Cut in half Standard Tip.
Then your Ears will a bit VACUUM, and you will hear a SOUNDSTAGE, you KNOW FROM 350€< In Ears, Everything sound Now, without a Ending, So AIRY!!!
OMG, How can I reduce the LOWER END NOW?????
It has so a STRENGTH DEPTH that is INCREDIBLE, my Triple Fi does not do that!!!!
I will go out and get some Air, I need to breath & calm down..
See you !!!
If you can find a way to tame that crazy sub-bass, also please let me know.
![wink.gif](http://files.head-fi.org/images/smilies/wink.gif)
