HairyHeadMara
- Apr 12, 2013
I never had any problem with any Zero Audio products I bought from Japan, I bought all Basso, Tenore, Singolo and Doppio from Amazon Japan and using Tenso.
Everyday that I read this thread I'm more nervous about getting my Tenores, they are already on destiny but well...I will get them on August.
Fingers crossed!
HairyHead, do your Doppio rank high on your list of IEMs, or are they just all Discovery Thread hype?
Anyone tried the RHA MA350 tips on them??? h34r:
Bore/ fit/ musical PERFECTION. :evil:
Can anyone clearly and concisely compare the tenore and doppio? Primarily detailed frequency analysis?
It's been a while since I owned the doppio but it has less extension on both ends and rolls off much sooner than the Tenore. While otherwise sounding fairly flat, it also has a dip somewhere in the upper mid (don't remember where) that makes it too smooth sounding. Distortion guitars lack proper bite and attack. Guitar driven rock was pretty boring as a result but vocals sounded pretty nice.
The F111 and RE400 are both more linear and accurate IMO and I know you've spend time with both if those. I'd take the KC06 over it, for FR, as well.
Thanks for the comparison! The dip in the upper mids region sounds like a bad idea especially considering that the Tenores have their only peak there and that they sound better for it.
It's not bad, actually fairly pleasing but if you are looking for accuracy and linearity, then I wouldn't recommend it; there are better options.
I'm not sure if I have mentioned on here but I did score a 'reference' Tenore a little while back. Today I was comparing with the balanced version of the RE400 and found the technical performance quite close to the reference Tenore.
I thought the Tenore sound a hair, and I mean just a hair bassier due to the flat extension but not due to any kind of boost, like on my bassier Tenore. Biggest difference was in treble, where the RE400b is more uneven in treble presentation. It's sounds a little brighter and slightly grainier/splashier when directly compared to the Tenore.
I'll have to spend more time with it but I really like both, I use ortofon silicone tips on the RE400b and can get a pretty comfortable, yet deep fit to even out the treble a little. The Tenore's staging was able to sound as spacious and as deep as the balanced run Hifiman.
All in all my current favorite iems are: UERM > Tenroe > RE400b > F111
