digitalmind
- Oct 24, 2005
The dint has me confused aswell. http://www.thefreedictionary.com/dint, a force or effort?
If he pops up online on MSN tomorow morning (He most of the time does) I'll ask him about the PSU, and also if it's fully balanced from the DAC. I think so -- if those pins that I circled are what I think they are (test pins or outputs for a possible internal headamp) it looks like a balanced setup. Also every channel has its own components, I can't see a single shared opamp or other thing. The whole PSU also looks like it's setup in two large single channel power supplies.
Originally Posted by philodox Good responses... sounds like the PSU may be linear if you need to specify voltage when you order. We should double check this. From the responses, I think that the Zhaolu D2.5C might be a good midground between the two in terms of tonality after what I have experienced with the AD and CS chips. Anyone know what 'dint' means? |
