arrow0309
Hi, the second one should be OK, 12v and 4.6A max is good. The Talema core is better or at least they say so.Does anyone have an alternative to the Fiio PL50 that also sells on Ali and works well with Aurora ?
I want to buy one but it simply isn't available on the 100-120v. (I looked many times on the last few weeks)
I asked Fiio about it and they just ignored me, so....
Maybe this: https://pt.aliexpress.com/item/1005004822737786.html?gatewayAdapt=glo2bra
Or this, as @arrow0309 noted above: https://pt.aliexpress.com/item/32975237936.html?gatewayAdapt=glo2bra
Which option to choose ? 12v or 15v (first option only have 12v tho, is it enough) ?
I'm noticing some hizz on my Arya Stealth, I hope it's a PSU issue that can go away with a change for a new and better one.....
One other thing is that you'd (better) need 5.5x2.1mm ("plug estilos"), mine is 2.5mm, a little bit loose but still working. 2.1mm is best for our Aurora.
