I consider them both medium-impedance IEMs that need amping or a decently powerful source to sound their best. They can seem treble-heavy when not driven properly, but it just takes more power to push their bass and mids out - they are in fact very balanced across the spectrum.
Note: I had the Yu9 made with a 4.4 balanced plug (for an additional $10) but used a 3.5 adapter for the purpose of A/Bing with the Ety. Switching back to balanced, I can clearly hear better control and imaging compared to SE, so the option is worth considering if you’re thinking of getting this.
Of course you can also use it with your own balanced cables if you’re getting the detachable cable version. I am not a fan of QDC-style connectors in general but have to say their cable is one of the better (and most secure) implementations of it that I’ve seen.
Very much my experience too - you need some drive to bring out the bass and low mids.
- Cable is excellent ergonomically - soft, supple, light, no memory of its own and not much by way of microphonics… but it has that awful chemical smell I’ve only smelled in cheapie KZ “upgrade“ cables. I’m airing it in the hope it will go away.
This is interesting, both my fixed cable 4B and the interchangable model didn't have any issues with a chemical smell. I think this is because you went for the 4.4mm termination which meant they had to wire a new cable. They probably used new stock straight off the roll with no time for airing.
