Nice job, man.
I just came across this thread and I'm very intrigued by these IEMs.
As I mainly listen to electronic music (Drum & Bass, Dubstep, etc), I bought a 7hz Timeless (it's very good), but I'm thinking about trying something different.
Which of the two would you recommend?
Also, I don't have a problem with deep insertion fit as I tried almost all IEMs of the ER 2, 3 & 4 series.
My recommendation would be the U-556 (the black model). It's more naturally attenuated high-mid / treble shifts the balance to the lower frequencies and everything sounds a bit meatier. Make sure you have a healthy bit of power from your source to bring the most out the BA bass, if you don't it might sound limp. As for speed and technical prowess the U-556 does great with electronic, although I must admit I don't listen to dubstep or D&B.
