pyrokid
- Feb 5, 2009
The kickside can be both, you just need to thin lube the bearing when you want to go unresponsive, and probably silicone it. (you take some permatex red gasket maker and put it into the little recess where the ring would usually go. Makes the binds way tighter, and if it's flush or less than flush, it makes it less responsive.) Oh yeah, and maybe shim it some.
and yeah, I have spent more on yoyos, haha.
By my last count, I had about 25 metals. And metals cost about 90-100 dollars on average. And I know for a fact I've given away about five hundred worth of stuff.
And then there's plastics...
haha.
by the way, all yoyos do play different, like how headphones sound different. And it is all preference. Which is thy I think if you wanna get into it, you should try as many different types of plastics as possible, to get to know what you like.
Originally Posted by Punnisher /img/forum/go_quote.gif A quick question: I am really interested in getting a Kickside (or maybe a similar one of better quality). Is there a certain bearing that I need in order to make it unresponsive? I'd like to experiment with both setups. |
haha.
