My buffers are soldered in |
Sigh...
should I leave them if I can't get them out? |
If you can't get them out, your only other option is to cut them off the board, clean the holes out, and get more buffers. And sockets.
But if I were you, and I were at the point where the buffers had to come out before I could do further testing, I would just toss the board, saving only the panel components and the expensive parts on the board, and start over. On a PIMETA with soldered buffers, that probably means saving only the op-amps and the pot if it's an RK27. I'd save C2/C3 only if they were exotic types, and C4 if you have installed them.
I took some readings with the AD8610 out of the ground. |
That's very strange. If the TLE were dead, you would either get a very bad split or no split at all. What you have is an accurate 1/2 V+ on virtual ground, but V- is just
missing. Very odd. I'd almost suspect broken board traces or something like that at this point.
Should I measure from the pins of the TLE2426 to PG? |
No, the other way 'round: measure from V+ to all three pins of the TLE. You should get 0, ~1/2 V+, and V+. The first would be the IN pin, the second the OUT, and the third the COM pin. If so, the TLE is working.
I'm assuming that I should be getting 18V at these chips, or close to it? |
Relative to virtual ground (PG), you should be getting approximately +9V at V+ and -9V at V-. You see that V+ on your chips is correct, but V- is missing, right? This is most curious.
Or since the ideal voltage is 18V I want a tenth of that, so I should get 1.8V. This is from Tangents trobleshooting guide. |
It says
within a tenth of a volt of ideal, not 1/10 of the supply voltage. Ideal is +/-9V. That means 8.9V and -9.1V is just fine. The reason you're getting more like 8.7V is almost certainly because your battery is no longer exactly 18V.
