I received an order of tubes that included the 12EL6. This tube is specifically mentioned in Pete's audioXpress article as one that might work (along with the 12AE6, 12AE6A, 12FM6, 12AJ6, 12FK6, 12FT6).
Well, it doesn't work. At least not in my amp. They burn brightly, but no sound at all. The bias on both tubes is locked hard at something like 27 volts (I run my amp at 29 volts)--can't dial them down. This sounds similar to the results
recently posted in the DIY forum regarding the use of 12AT6 and 12AV6 tubes. In that thread, Pete is quoted as saying the AT and AV tubes require much higher voltage--perhaps this is the problem with the 12EL6 as well. So for now, it appears the 12EL6, 12AT6, and 12AV6 probably won't work properly, unless both my NOS 12EL6's are defective or another brand would work (not likely). Someone suggested that the 12AE6 won't work, but I have four 12AE6 tubes now and they all work fine in my amp. They do seem to sound a bit different from the 12AE6A--perhaps less detailed, less bass... inferior to the 12AE6A, IMO.
BTW, I personally like how the 12FM6 sounds: dark, tubey, liquid, smooth, laid back, bassy, etc. I only received one 12AJ6 unfortunately, but this tube has been commented on already.
-coma
