sander99
"as the A8/A16 headtrackers should output properly with the speaker arrays of the Yarra"Should be interesting using the A8 or A16 with the Yarra sound bar as the A8/A16 headtrackers should output properly with the speaker arrays of the Yarra...
http://idfrancetv.fr/wp-content/uploads/2017/09/OBA17_Beamforming-Transaural-Soundbars-Simon.mp4?_=6
I don't know exactly what you mean with this, but the standard headtracking of the A8/A16 will not give a correct result in this situation (using the A8/A16 with the Yarra). When looking forward the sound from the Yarra is coming from the front center (assuming you put the Yarra centered in front of you). That means that the binaural signal should be filtered with the inverse of your center-front HRTF (otherwise the binaural signal will have an additional center-front-HRTF overlayed on all the HRTF filtering that the A8/A16 has already done). This hopefully can be realised by doing a HPEQ of the Yarra in front of you (you in your normal listening position looking forward center). However if you turn your head for example 30 degrees to the left, the natural HRTF signal being overlayed on the binaural signal now corresponds to sounds coming from 30 degrees right. So at this moment the HPEQ does not do the proper compensation. At this moment there should be an additional filtering - instead of what the HPEQ currently does - with the inverse of your HRTF for 30 degrees right!
Additional clarification: note that all the time the A8/A16 will create a proper binaural signal for headphones, correctly compensated for the head movement, but the problem is in the changing natuaral acoustic HRTF filtering that this signal will go trough on it's way from the Yarra to your ears.
In fact turning the head tracking off will probably cause less problems for sounds coming from the front. But the best result you will only have while looking straight forward.
[Edit: actually there are similar problems with the Inter Aural Time Delay: when you turn your head to the left there will be a longer travel time from the Yarra to your left ear than to your right ear. The A8/A16 will not have compensated for that (because with headphones moving your head the drivers stay at the same distance to your ears).]
