Pars
Can Jam '10 Organizer
- Oct 28, 2003
There are many Cmoy troubleshooting threads here. Example 1, example 2.
One thing that I always suggest for problems like this is to remove the opamp and ohm out each pin on the socket to ground, against the schematic (covered in both example threads). Then ohm out adjacent pins, and trace out the feedback loops. A problem here is more than likely causing your symptoms. Reflow your solder joints and make sure that component leads and wires are thru the board far enough.
