ROBSCIX
- Aug 25, 2005
Are you using the proper setting on the headphone amplifer as this usually seems to be the reason for brightness. You will have to change out the I/V opamps...
Originally Posted by bogglor /img/forum/go_quote.gif Does anyone know what kind of opamps I can use to tame the high end of the very common HD650 + Essence ST combo? I don't think people I've read many complaints about this combo being bright (?) with the stock opamps, but I am finding it kind of fatiguing to listen to rock/pop music on these cans with a flat EQ. I'm really enjoying audiophile grade and jazz recordings but even though the HD-650s have a rep for a laid back presentation, I'm finding the highs a little aggressive. Suggestions? |
Originally Posted by ROBSCIX /img/forum/go_quote.gif Many people have been asking me for the Beta's. I don't htink you will be waiting too much longer for the released versions. Maybe I will ask and see what I can do for the peopel that have been asking. I will keep you posted. |
Originally Posted by ROBSCIX /img/forum/go_quote.gif Are you using the proper setting on the headphone amplifer as this usually seems to be the reason for brightness. You will have to change out the I/V opamps... |
Originally Posted by bogglor /img/forum/go_quote.gif When you say proper setting, do you mean extra high gain? They're 300 so I figured that was correct. |
Originally Posted by ROBSCIX /img/forum/go_quote.gif The tenadancy for some is to over amp them which gives way too much gain and makes the card too bright. How does high gain sound to you? |
Originally Posted by ROBSCIX /img/forum/go_quote.gif The card can electrically drive any headphone-thats has been tested with them in the thread. Many people have tried the cards with the HD650's. I can't remember any user with the Denons but I cannot see any issue as the can amplifer chip has loads of power. To note, some with higher end headphones use the ST/STX as a DAC and send the line out to an external headphones amplifer for higher grade sound. |
Originally Posted by ROBSCIX /img/forum/go_quote.gif Well the opinions of this card frompeopel that have actually tested are great. Botht he STX and ST use high quality components and the measurments are some of the best seen in any PC audio gear. Some use the line out for speakers. You can use the lineout if you have heapdheons with low impedance as they do not require the amplifer. Technically the line out is of higher quality then the can output. There are also a few mods to improve it further. Were you playing with the bass redirection when using the headphones? Have a look in there and adjust it and see if it helps. Usually bass redirection is used for surround system but these cards allow you to set the bass cutoff for your cans also, IIRC. which OS are you using? |
