xnor
- May 28, 2009
Thank you for this incredibly worthless post, anwaypasible. It's always a pleasure.
You really should read a book, or two.
[...] considering how much this card has been praised and how big of a difference most people seem to get when the gain is increased, [...]
This is head-fi, after all, so I'm not surprised.
If you have a loopback cable just connect headphone out with line in and run RMAA, a free tool to measure the performance of the card.
Just a gain, right.... Ok, if gain is 0dB you may listen 44/16 sources as is. And what happen if you will decrease gain? I mean what happen with bit-depth in this case?
i'm not sure what are you referring to but i think you're confusing amplifier gain with digital volume attentuation.
I used audacity to compare a couple of songs (in flames - come clarity, metallica - sabbra cadabra, a perfect circle - the package, massive attack - angel) with normal and high gain setting. I decreased the gain on the track in audacity to compensate for the increased volume when changing from normal to high gain in the essence audio center, so the difference in volume was removed.
